How to get part documents from draft file?
I want to retrieve properties of parts present in draft file. Here we have draft file as input. What are the steps to get part documents of parts present in draft file?
If anybody has example, Please share it.
Thanks in advance.
-Amit
Posted by: Amit Wadekar
Post date: 5/8/2012 9:36:14 AM
Re: How to get part documents from draft file?
Amit,
you get access to the referenced model(s) from a draft file as follows:
Loop through all sheets of the Sheets collection of the DraftDocument object.
Loop through all DrawingView objects of the DrawingViews collection of each Sheet object.
The ModelLink object of a DrawingView object is what you are searching for.
Posted by: Wolfgang Kunert
Post date: 5/9/2012 2:31:11 AM
Hi Amit,
As Wolfgang Kunert said you can use the "ModelLinks" object. And here is an exemple :
Dim dftDoc As SolidEdgeDraft.DraftDocument
Dim sEApp As SolidEdgeFramework.Application
Dim occurrences As SolidEdgeAssembly.Occurrences
Dim occurrence As SolidEdgeAssembly.Occurrence
'Get your Draft document
dftDoc = sEApp.ActiveDocument
Dim oChildModels As SolidEdgeDraft.ModelLinks = dftDoc.ModelLinks
Dim oChildModel As SolidEdgeDraft.ModelLink
Dim obj As Object
Dim objPart As Object
For Each oChildModel In oChildModels
obj = oChildModel.ModelDocument
'Your treatment here..
'if linkModel is an assembly you can get your Part documents using "Occurrences" object :
occurrences = obj.Occurrences
For Each occurrence In occurrences
objPart = occurrence.OccurrenceDocument
'Your treatment on Parts here..
Next
Next
Tamer
Posted by: Tamer EL BAKKALI
Post date: 5/9/2012 6:27:02 AM
Thank you Wolfgang Kunert and Tamer for your quick reply. Smiley Happy
Post date: 5/10/2012 12:40:32 AM
