How to get the Active Configuration for SolidEdge Assembly document
  I am trying to find the active Components (Parts or sub-assemblies) for a given Assembly with respect to active configuration. So i used the Configurations interface which fetched me the collection of configurations. My problem is that
Code..
// get the active document
SolidEdgeAssembly.AssemblyDocument objAsm = (SolidEdgeAssembly.AssemblyDocument)seApp.ActiveDocument;
// get the collection object for configuration
SolidEdgeAssembly.Configurations Config = (SolidEdgeAssembly.Configurations)objAsm.Configurations;
For (.....
SolidEdgeAssembly.Configuration ActiveConf = (SolidEdgeAssembly.Configuration)Config.Item(CountConfig);
// Configuration name
ActiveConf.Name
1. How to find which is the active configuration in the obtained list of Configurations && one Configuration is repeating twice everytime,  why?
2. After getting the active configuration, how to get the parts,sub-assemblies which are active (i know we can only traverse through active components ).
I used the Revision Manager --> Linked documents ,but that is getting all the components irrespective of the active configuration && irrespective of component is active or inactive.
Any help in this regard appreciated.
Thanks in advance.
Venkata Ramesh V
Posted by: Venkata Ramesh Virodhula
Post date: 7/20/2011 12:39:23 AM
