How to get the active profile?
Hey guys,
I started with the Solid Edge API 2 weeks ago and there are still some difficulties to achieve my first successes. My programming skills are based on native C and a little bit C++.
My main problem is to get the active profile.
All the examples I found show how to create a new profile, but I need the active and I was not able to get it by myself.
I searched the help, but I found nothing that really helped. I already found the examples by Jason Newell and his "Solid Edge Spy". That helped me a lot but not in this special case.
The situation:
I have an open part document with an already opened sketch that shows 5 lines (somewhere and not connected).
What i want to achieve is to produce a duplicate of the clicked line.
Can anybody please help me with this?
I attached a started project if that makes things easier.
Greetings,
starger.
Re: How to get the active profile?
Hi starger,
use the ActiveSketch of the ActiveDocument.
JB
SE ST10
Hello Starger,
I'll show you an example in C # to show you the step-by-step.
I've highlighted the field of code you need to get the active sketch.
 class Program
        [STAThread]
        static void Main(string[] args)
            // Declare your main variables
            SolidEdgeFramework.Application seApplication = null;
            SolidEdgeFramework.Documents seDocuments = null;
            // Declare your document variables
            SolidEdgePart.PartDocument sePartDoc = null;
            // Variables and Objets for Sketchs
            SolidEdgePart.RefPlanes planesCollection = null;
            SolidEdgePart.RefPlane workPlane = null;
            SolidEdgePart.Sketchs sketchsCollection = null;
            SolidEdgePart.Sketch sketch = null;
            SolidEdgePart.Profiles profiles = null;
            SolidEdgePart.Profile workProfile = null;
            // Variable of Lines and Relationships
            SolidEdgeFrameworkSupport.Lines2d linesCollection = null;
            SolidEdgeFrameworkSupport.Relations2d relationsCollection = null;
            try
                // Register
                OleMessageFilter.Register();
                // Connect your Solid Edge
                seApplication = SolidEdgeUtils.Connect(true);
                // Get your Document Collection
                seDocuments = seApplication.Documents;
                // Check for any active part document
                if (seApplication.ActiveDocumentType != DocumentTypeConstants.igPartDocument)
                    // If don't have a part document active, break this code
                    return;
                // Get Active Document
                sePartDoc = (PartDocument)seApplication.ActiveDocument;
                // Get time for the program
                seApplication.DoIdle();
                // Get the reference plane
                planesCollection = sePartDoc.RefPlanes;
                // Get the top plane
                workPlane = planesCollection.Item(1);
                // ---> Get the Active Sketch <---
                sketch = sePartDoc.ActiveSketch;
                // Get the profile collection
                profiles = sketch.Profiles;
                // ---> Get active profile <---
                workProfile = profiles.Item(1);
                // Get the reference of lines 2d collection
                linesCollection = workProfile.Lines2d;
                // Create three lines
                linesCollection.AddBy2Points(0, 0, 0.1, 0.1);           // Your first line, Item(1)
                linesCollection.AddBy2Points(0.1, 0.1, 0.1, 0);         // Second line, Item(2)
                linesCollection.AddBy2Points(0.1, 0, 0, 0);             // Third line, Item(3)
                // Get the reference of relationships
                relationsCollection = (Relations2d)workProfile.Relations2d;
                // Create three new connection relationships
                relationsCollection.AddKeypoint(
                    linesCollection.Item(1),
                    (int)SolidEdgeConstants.KeypointIndexConstants.igLineEnd,
                    linesCollection.Item(2),
                    (int)SolidEdgeConstants.KeypointIndexConstants.igLineStart);
                    linesCollection.Item(3),
                // Create two new alignment relationship, Horizontal and Vertical
                relationsCollection.AddVertical(linesCollection.Item(2));
                relationsCollection.AddHorizontal(linesCollection.Item(3));
                // End Sketch/Profile
                workProfile.End(ProfileValidationType.igProfileClosed);
            catch (Exception e)
                Console.WriteLine(e.Message);
            finally
                // Ungister
                OleMessageFilter.Unregister();
To copy a line, you can get points X1, Y1 and X2, Y2 and create a new one based on these positions.
To get these points by click, use the SelectSet class.
If you are interested in learning more about Solid Edge API in C #, link below:
https://www.youtube.com/playlist?list=PLZyAyG4_KmYk8nYLT9k9M2ttKL7JQ0nTF
Have a nice day.
Kabir Costa
Industrial Designer
kabircosta@gmail.com
Thank you guys. That really helped me.
