How to get the name of "Group"?
Hi all:
   In the Dft, I want to get the Group's name.
   I use the group.get_name(), but error.
   In help, This has a object --- Recurse Parameter , What is this?
   Please help!
   Thanks!
Posted by: fat kids
Post date: 11/21/2010 3:59:15 PM
3 REPLIES 3
RE: How to get the name of "Group"?
As far as i know, i never heard about a get_name() function or a recurse parameter.
In the Group object you have a Group.Name property which is the internal name that SOlid edge gives to any group and the Group.UserdefinedName which is the name that the user manually gives to a Group.
HTH,
Julian
Posted by: Julian Guillo
Post date: 11/22/2010 11:35:36 AM
Thanks, Julian Guillo!
"UserdefinedName" is what I want.
But,
SE-ST's help file has Group.Name description, but not in the VS2008's object browser, only Group.get_Name
Posted by: fat kids
Post date: 11/22/2010 6:02:10 PM
I haven't checked, but I assume that you're using C# and Name is a parameterized property. C# doesn't support properties with a parameter (with the exception of indexers) so any imported COM properties that have one are split into get_PropertyName and set_PropertyName methods.
Calum
Posted by: Calum McLellan
Post date: 11/22/2010 9:25:51 PM
