How to identify object type while looping through items in a selectset?
I am pretty new to SolidEdge Automation & the use of its vast API. I just wanted to know how to identify if all items returned by the ActiveSelectSet are suppose HoleTables. I have deciphered from some of the samples at Codeplex how I can loop through each item one by one but cant figure out how to determine the type of each item.
Govind
Re: How to identify object type while looping through items in a selectset?
For i As Integer = 1 To oSel.Count
  If TypeOf (oSel.Item(i)) Is SolidEdgeDraft.HoleTable Then
    oHT = oSel.Item(i)
    MessageBox.Show(oHT.Holes.Count.ToString())
  End If
Next
where the following are declared earlier:
Dim oSel As SolidEdgeFramework.SelectSet
Dim oHT As SolidEdgeDraft.HoleTable
For more language options see this:
http://surfandcode.blogspot.in/
