How to implement 'Connect' Relationship through vb.net program
PLM World Member Pioneer PLM World Member Pioneer
Hello All,
I need to add relationships to a drawing.
I am able to add parallel and perpendicular and other functions.
But for 'Connect' I found the method 'AddKeyPoint' will do the 'Connect' functionality.
See the attached screenshot.
Through 'AddKeyPoint' method I am able to connect as shown in screenshot in the right side. But my requirement is as shown on left side of the screenshot. Which method should I use please help.
Thank you
If you'll share your code to reproduce the example in the...
If you'll share your code to reproduce the example in the screenshot, I'll take a look at it.
Jason Newell
Applications Architect
www.jasonnewell.net
