How to insert Isometric view ?
Dear experts.
How do I add an isometric view in the draft sheet? I'm using the following code:
drawingView = drawingViews.AddAssemblyView(From: modelLink,
                                                           Orientation: SolidEdgeDraft.ViewOrientationConstants.igTopView,
                                                           Scale: 0.2,
                                                           x: 0.5,
                                                           y: 0.2,
                                                           ViewType: SolidEdgeDraft.AssemblyDrawingViewTypeConstants.seAssemblyDesignedView);
The Enum "SolidEdgeDraft.ViewOrientationConstants" doesn't have an igIsometricView option.
This option is in another enum: SolidEdgeDraft.DrawingViewTypeConstants. But I can't find a property in the drawingView object which accepts it.
Do you know how to accomplish this task?
Thanks in advance!
Re: How to insert Isometric view ?
there exist not only one ISO view but eight.
Use the igTopFrontRightView constant, this should do what you expect
JB
SE ST10
Hello, JB !
Thanks for your explanation. It helped me a lot!
