How to know if Solid Edge installed or not?
Hi.
I am writing installer and before add-in installation i want to know if the Solid Edge ST4 installed. For this i want to check registry for SE key, thats creates when Solid Edge installed. Does anybody know what key i need to search in registry? Or where i can find information about this?
I found this keySmiley Frustratedoftware\Microsoft\Windows\CurrentVersion\Uninstall\{3F084E0E-E7D3-439D-9AC3-8312B2184347}
But i don't know is it right key for my need? and is this key for x64 and x86 systems?
Posted by: Walker
Post date: 7/5/2012 8:00:16 AM
Re: How to know if Solid Edge installed or not?
Walker,
you may use the WMI API to list and search for installed software. Some information and examples are provided http://technet.microsoft.com/en-us/library/ee156540.aspx]here.
Posted by: Wolfgang Kunert
Post date: 7/6/2012 2:29:16 AM
This can easily be resolved by using the Solid Edge Install Data Library (SEInstallData.dll).
Posted by: Jason Newell
Post date: 7/20/2012 2:10:44 AM
