How to know that SE is opened again
    I'm developing an application which generates a 3d model using SE APIs. Im using vb.net for that (vs 2008).
While generating 3d models, SE is invisible. Now if somebody opens solidedge while my app is still updating variables etc then my app gets into trouble. I dont want this to happen. Can I know that SE app is requested to open by user by hooking to some  event etc. I tried to hoot to BeforeEnvironmentDeactivate() event ,which is successful, but I don't know how to cancel that SE open process.
Is there any way ?
Thnaks in advance,
Myth.
Posted by: Mithun **bleep**ole
Post date: 5/15/2009 2:24:26 AM
RE: How to know that SE is opened again
No way out????
Post date: 5/17/2009 8:44:32 PM
I'm assuming that you do not mean that user starts a 2nd session of Solid Edge. If that assumption is correct, then you can use some of the Application object properties like:
application.DisplayAlerts = false
application.Interactive = false
application.ScreenUpdating = false
application.Visible = false
Use my Solid Edge Spy to easily see what options are available.
Posted by: Jason Newell
Post date: 5/19/2009 12:09:20 PM
Jason, your assumption is correct. But i didn't understand what you exactly suggesting.
Does this mean that i should check for these properties for change?
means say from app.visible=false to app.visible=true to detect app is opened by user?
Post date: 5/20/2009 2:39:09 AM
