How to know the value of IncludeinBOM property?
I try to do a Bill of Material without (solidedge.application), all work fine... but I need to filter on the includeinBOM property. Is it possible to know the value of IncludeInBOM property with revision manager or file properties?
Thanks for your answer.
Regards from the french riviera.
Posted by: Lionel Gonda
Post date: 3/20/2007 9:23:47 AM
RE: How to know the value of IncludeinBOM property?
Lionel,
I took a look at it this morning and I just don't see a way to get that value other than using the full Solid Edge API. Maybe someone else has an idea?
Posted by: Jason Newell
Post date: 3/21/2007 1:14:59 AM
