How to make Solid Edge Addin environment specific?
Hi Jason,
I have question regarding Solid Edge Addin created using your Solid Edge Addin Wizard. How to make Solid Edge Addin environment specific? Right now this addin is ON in all environments(part,assembly,draft,sheetmetal,etc.). I want to make it ON in part and assembly environments only. Is there any changes to be done in project for this?
Thanks in advance.
-Amit
Posted by: Amit Wadekar
Post date: 8/2/2011 3:53:54 AM
RE: How to make Solid Edge Addin environment specific?
Problem is solved...!!!
Post date: 8/3/2011 1:02:16 AM
