How to open a Document silently in SolidEdge
How can we open a document silently in SolidEdge, Silently means it should not be visible to the user.
Avi
Posted by: rajesh panda
Post date: 7/17/2009 1:44:18 AM
RE: How to open a Document silently in SolidEdge
you can try for example with GetObject("d:\test.par")
jr
Posted by: JR
Post date: 7/17/2009 2:28:25 AM
Thanks for the reply jr.
Can you please elaborate on how we can open a document silently (in invisible mode) . I am using C++
Avi
Post date: 7/17/2009 2:39:49 AM
Public Function CreateSEApp()
'Create Solid Edge instance
Set SEApp = CreateObject("SolidEdge.Application")
SEApp.Visible = FALSE
SEApp.DisplayAlerts = FALSE
End Function
Don't forget to reset the visibility and DisplayAlerts to True!
Posted by: Bill Ledbetter
Post date: 7/17/2009 2:40:36 AM
Thanks Bill,
But the code given by you makes SolidEdge Application invisible.
I want to make the document invisible and not the SolidEdge application.
Avi
Post date: 7/17/2009 3:11:51 AM
Then all I can think of is minimizing the window in which the part lies.
Post date: 7/17/2009 3:15:57 AM
Bill,
How can we do that ?
Avi
Post date: 7/20/2009 2:09:12 AM
'Open Document
Set NewAssy = seApp.Documents.Open("C:\Drawings\Model.par")
'Hide active window
SEApp.ActiveWindow.WindowState = 1
'Do required actions
'Restore Window
SEApp.ActiveWindow.WindowState = 2
'Reset Display alerts and release objects
SEApp.DisplayAlerts=TRUE
SEApp=Nothing
Post date: 7/20/2009 2:37:08 AM
Avi,
You can also make the document related windows invisible. (VB code untested)
Dim oWin as Window
for each oWin in SEApp.ActiveDocument.Windows
oWin.Visible = False
next
Julian
Posted by: Julian Guillo
Post date: 7/21/2009 1:01:11 AM
Julian,
I triend the solution given by you. But Windows and WindowState both are properties at the application level and hence we cannot control the visibility of a particular document using these properties.
If we make WindowState = 1 or Window.Visible = false, then whole application is minimised and not a particular document.
Avi
Post date: 7/22/2009 2:28:41 AM
