RE: How to open a Document silently in SolidEdge
Avi,
Windows exists also at document level which is the solution i proposed you.
I tested my solution and it works well. (Code is VB.net now). You must just translate this into C++
Dim SEApp As SolidEdgeFramework.Application
Dim oPart As SolidEdgePart.PartDocument
Dim oWIn As SolidEdgeFramework.Window
'Get Solid Edge instance. Solid Edge must be open.
SEApp = GetObject(, "SolidEdge.Application")
oPart = SEApp.ActiveDocument 'A part document must be active
oWIn = oPart.Windows.Item(1) 'Get the first window for this document
oWIn.Visible = False 'Make it invisible
oWIn = Nothing
oPart = Nothing
SEApp = Nothing
Posted by: Julian Guillo
Post date: 7/22/2009 4:08:12 AM
Avi,
you may use the following code, which has already worked for me in the past.DocumentsPtr pDocs = pApp->GetDocuments();
VARIANT vOption;
V_VT( &vOption ) = VT_UI4;
V_UI4( &vOption ) = (unsigned long)8L;
DocumentPtr pNewDoc = pDocs->Open( strDocName, vOption );
The option code 8 avoids creating a window for the new document.
Good luck,
Martin
Posted by: Martin Bernhard
Post date: 7/24/2009 12:45:53 AM
Thanks a lot Martin for the Solution It worked perfectly well the way I wanted.
I made a small change here, Instead of using DocumentPtr, I used IDispatchPtr and then typecated it to get the respective pointer.
Thanks Again Martin.
Avi
Posted by: rajesh panda
Post date: 7/27/2009 1:25:34 AM
After using the above code the .par documents are opened silently but the sub-assemblies are still visible in the solid edge application when trying to open silently using above code.
Also, the assmebly document (.asm) is opened in cascade form within solidedge application and not in fully maximized form. so problem is
1) How to open sub-assemblies in invisible mode?
2) even if it opens in visible mode how to open in maximized form, rather than cascaded form.
Thanks & Regards
Amey
Posted by: amey k
Post date: 11/15/2009 3:42:58 AM
