How to programmatically align Different views(Front,left,right etc.) in Drawing?
Hello ,
I am trying to generate drawings using Solidedge programmign interface.I can successfully generate particular views like front view,right view,left etc.
But these views moves here n there irresepect to each other.Through UI we can align them by right clicking on a view and then saying Create Alignment.
But through program we need to align them by DrawingViews.Align()
BUt its not working....I am also sending the code....
Please help i have searched for this everywhere but couldnt found anything ...........I hope you people can help me in this issue.....
Even SDK doesnt have proper explanation for the method...I am using VB for programming....Dont worry its similar to VB.Net
Program..............
Public objApp As SolidEdgeFramework.Application
Dim objSourceDoc As SolidEdgeDraft.DraftDocument
    On Error Resume Next
    Set objApp = GetObject(, "SolidEdge.Application")
    If Err Then
        Err.Clear
        Set objApp = CreateObject("SolidEdge.Application")
        objApp.Visible = True
    Else
    End If
    Set objSourceDoc = objApp.Documents.Add("SolidEdge.DraftDocument")
    Dim objDrawingViews As SolidEdgeDraft.DrawingViews
    Dim objDrawingView1 As SolidEdgeDraft.DrawingView
    Dim objDrawingView2 As SolidEdgeDraft.DrawingView
    Dim objModelLink As SolidEdgeDraft.ModelLink
    Set objSourceDoc = objApp.ActiveDocument
    Set objModelLink = objSourceDoc.ModelLinks.Add("C:\ESSILProject\Try\Assembly\Final.asm")
    Set objDrawingViews = objSourceDoc.Sheets(1).DrawingViews
    Set objDrawingView1 = objDrawingViews.AddAssemblyView(objSourceDoc.ModelLinks(1), igFrontView, 1, 0.25, 0.25, seAssemblyDesignedView)
    Set objDrawingView2 = objDrawingViews.AddAssemblyView(objSourceDoc.ModelLinks(1), igRightView, 1, 0.5, 0.5, seAssemblyDesignedView)
    Dim sel As SolidEdgeFramework.SelectSet
    Set sel = objApp.ActiveSelectSet
    Call sel.RemoveAll
    Call sel.Add(objSourceDoc.Sheets(1).DrawingViews(1))
    Call sel.Add(objSourceDoc.Sheets(1).DrawingViews(2))
    objSourceDoc.Sheets(1).DrawingViews.Align
If you want test this im sending the Final.asm file else you can use any of your file for this.......................
Posted by: Gaurav patil
Post date: 9/8/2008 10:19:45 PM
RE: How to programmatically align Different views(Front,left,right etc.) in Drawing?
Does anyone out there know the answer to this? I've been trying to align drawing views for a while now but to no avail.
Posted by: T Kin
Post date: 10/9/2008 2:36:55 AM
Instead of trying to align the DrawingViews I have used the AddByFold method to create aligned views...
objDrawingView2 = objDrawingViews.AddByFold( _
objDrawingView, _
FoldTypeConstants.igFoldRight, _
dblX, _
dblY)
Posted by: Scott Hadley
Post date: 10/29/2008 9:24:28 AM
