How to read, from a draft, the file properties of the part / assembly
When I create a draft from a part / assebly I want to copy their properties.
Who can tell me how to retrieve, from a draft, the part / assembly properties with a .NET program ?
Posted by: francesco marcheluzzo
Post date: 1/24/2010 7:58:15 PM
RE: How to read, from a draft, the file properties of the part / assembly
I read the ".Net Programmer's Guide" and now I know how to copy the part or assembly properties into the relative drawing with a macro.
Now I'd like to execute the macro automatically when I create the drawing from the part / assembly.
Maybe I need an Addin ?!?
Post date: 1/25/2010 3:53:50 AM
you can read the part/assy properties directly into the drawing textboxes. So you don't have to copy them to the draft properties. We use this methode in our draft templates and works fine. This way you store the properties in only 1 place, the part/assy file properties, and you don't need any code.
First make a "callout" in your draf document.
Then click "property text" in the bottom left
Select the link you want to use.
For example: "%{File Name|R1}"      (This gives you the filename of the first modellink of the drawing)
Posted by: harry dijk
Post date: 2/4/2010 8:20:08 PM
Thanks for your useful suggestion. Regards.
Post date: 2/11/2010 10:18:59 PM
