How to return E_NOTIMPL to OnFileSaveAsUI Event?
After reading all I have found this theme, I don't know how to return a Value to this event. Can anybody give me a hint? I know, I'm just near the solution.
Thanks in advance,
Andreas
Posted by: Andreas Baumann
Post date: 6/17/2012 3:52:54 PM
Re: How to return E_NOTIMPL to OnFileSaveAsUI Event?
Andreas,
i didn't verify myself, but on page 122 of the Solid Edge .NET Programmer’s Guide is stated to throw an System.NotImplementedException:
[i]File UI Events
The File UI events allow you to watch for specific UI events. The File UI events are somewhat different
in other events because if you do not wish to override the default functionality, you must throw a
System.NotImplementedException. Failure to do so will indicate to Solid Edge that you have a custom
UI that you wish to display to the user. You can obtain a reference to these events by attaching to the
FileUIEvents property of the Application object.[/i]
Posted by: Wolfgang Kunert
Post date: 6/18/2012 1:51:38 AM
