How to select dimension in draft SE20?
I am trying to select dimensions in draft module thorugh VB6 code. But I don't know where to start!
Any source code will be helpful.
Please help,
MG
Posted by: marijan glavac
Post date: 8/3/2009 10:33:42 PM
11 REPLIES 11
RE: How to select dimension in draft SE20?
Hey,
This code example connects to a collection of dimensions in the first sheet. I haven't tested it, but it should get you started.
Good luck!
Wouter
Public Sub DraftDimentions()
On Error Resume Next
Dim objApp As SolidEdgeFramework.Application
Dim objDoc As SolidEdgeDraft.DraftDocument
Dim objSheet As SolidEdgeDraft.Sheet
Dim objDimensions As SolidEdgeFrameworkSupport.Dimensions
Dim objDimension As SolidEdgeFrameworkSupport.Dimensions
Dim strFName As String
Dim i As Integer
strFName = "myDraft.dft"
'Get SE ans open doc
Set objApp = GetObject(, "SolidEdge.Application")
If Err Then
Err.Clear
Set objApp = CreateObject("SolidEdge.Application")
End If
objApp.Visible = True
objApp.Activate
objApp.DisplayAlerts = True
objApp.DisplayFullScreen = True
'Set
Set objDoc = objApp.Documents.Open(strFName)
Set objSheet = objDoc.Sections.WorkingSection.Sheets(1)
Set objDimensions = objSheet.Dimensions
'Connect to the dimentions
For i = 1 To objDimensions.Count
Set objDimension = objDimensions.Item(i)
'DO WHAT EVER YOU WANT HERE >>>>>>>>>>>>
Next
'Destroy Variables
Set objApp = Nothing
Set objDoc = Nothing
Set objSheet = Nothing
Set objDimensions = Nothing
Set objDimension = Nothing
End Sub
Posted by: Wouter Sloof
Post date: 8/4/2009 9:26:49 PM
Thank you !
It is a great help. Do you know how to select dimension on draft with mouse and get all dimension information (sufix,prefix) ?.That I need a most.
Post date: 8/7/2009 3:23:19 AM
No sorry, I don't know that.
Post date: 8/9/2009 11:45:08 PM
try this:
Dim i As Integer
Dim objSelSet As SolidEdgeFramework.SelectSet
Dim pre_fix As String
Dim suff_fix As String
'Dim objHSets As SolidEdgeFramework.HighlightSets
'Dim objHSet As SolidEdgeFramework.HighlightSet
'Set
Set objDoc = objApp.ActiveDocument
Set objSheet = objDoc.Sections.WorkingSection.Sheets(2)
Set objSelSet = objDoc.SelectSet
'Set objHSets = objDoc.HighlightSets
Set objDimension = objDimensions(i)
pre_fix = objDimension.PrefixString
suff_fix = objDimension.SuffixString
'Select in the Draft
Call objSelSet.Add(objDimension)
'Highlight if need
'Set objHSet = objHSets.Add
'objHSet.AddSelected
'objHSet.Draw
Next
'Destroy Variables
Set objSelSet = Nothing
End Sub
jr
Posted by: JR
Post date: 8/10/2009 10:36:58 PM
I need to select dimension with mouse in draft and from thet selectetd dimension get information.
Post date: 8/12/2009 12:50:30 AM
do you want to move the mouse and click on the dimension?
Posted by: JR
Post date: 8/12/2009 12:55:26 AM
yes , and from selected dimension get all information (suffix,prefix)
Post date: 8/12/2009 12:58:32 AM
I don't know that. Without move the mouse see coding above (SelectSet).
You can read the position of the mouse, but move ...? I think this is not so simply, maybe with Windows API... (?)
Posted by: JR
Post date: 8/12/2009 1:15:07 AM
Must be some simple way.
When I want to do same thing in VBA for AutoCad or ZWCad I use code:
Dim returnObj As ZwcadEntity
Dim basePnt As ZwcadPoint
ThisDocument.Utility.GetEntity returnObj, basePnt, "select object :"
Debug.Print returnObj.EntityName
On graphical screen I can select what ever I want.
How to do that in SE ?
Post date: 8/12/2009 1:26:15 AM
