RE: How to select dimension in draft SE20?
you must use object SelectSet
in my coding above:
For i = 1 To objDimensions.Count
Set objDimension = Nothing
Set objDimension = objDimensions(i)
'Example for prefix and suffix:
pre_fix = objDimension.PrefixString
suff_fix = objDimension.SuffixString
'Set selection in the draft
Call objSelSet.Add(objDimension)
'now is the dimension selected in the draft
Posted by: JR
Post date: 8/12/2009 1:49:32 AM
Re: RE: How to select dimension in draft SE20?
Hi, all
I try this code and it select all dimention, how do that, this code will be modify a prefix dimention which i select by mouse ?
