How to select suboccurrence ?
How to select suboccurrence via API ?
When i run this code
SolidEdgeFramework.SelectSet SS=Application.ActiveSelectSet;
SS.Add(Occ); //Occ is SolidEdgeAssembly.Occurrence object
SS.Add(SubOcc); //SubOcc is SolidEdgeAssembly.Suboccurrence object
i get result:
Occ is selected.
SubOcc is not selected.
Thanks.
Posted by: Juraj Joob
Post date: 1/11/2010 9:11:43 PM
RE: How to select suboccurrence ?
Alredy I know, how to select suboccurrence. Suboccurrence is not selectable, but reference is selectable. I create reference from suboccurrence and select it with SelectSet.Add(Reference). Here is example in C#:
SolidEdgeAssembly.AssemblyDocument A=SubOcc.TopLevelDocument;
SolidEdgeAssembly.Occurrence O=(SolidEdgeAssembly.Occurrence)SubOcc.Parent;
SolidEdgeFramework.Reference R=(SolidEdgeFramework.Reference)A.CreateReference(O,SubOcc.ThisAsOccurrence);
Post date: 1/12/2010 1:58:10 AM
Post date: 1/12/2010 1:58:12 AM
