How to set position in draft document?
Hello!
I am faced with the following problem - how to set positions in the draft document. What does it mean? Look at the picture:
I want to fill value in the circle by its values, which have my program. So, which methods or classes can I use to edit this object?
Re: How to set position in draft document?
What you have highlighted is either a Balloon or Leader object.
You can use the SE Spy for this.
Dim oBalloons As Balloon = oSheet.Balloons
To set the position use:
oBalloon.SetKeyPoint(x, y, z) or soem method like that. I am worling from memory so not sure about this.
To set the text, use:
oBalloon.BalloonText = "Ballon Text Here"
Hope that was useful.
BR,
Tushar Suradkar
Thank you!
