How to start SE invisible (instead of .visible=false after started)
Is there a way to start up solid edge invisible?  I know you can set .visible = false after it is open, but we would like it to start up that way for a particular utility.
Posted by: Brent Newsom
Post date: 8/6/2008 6:44:43 AM
RE: How to start SE invisible (instead of .visible=false after started)
Brent,
You need to show us your code. I'm confused by the question because when you create an object using 'SolidEdgeFramework.Application', it's invisible by default.
Posted by: Jason Newell
Post date: 8/8/2008 4:43:16 AM
