How to test for Custom Prop?
All,
I am trying to test to see if a custom property named "Total Cost" exsist.
I am currently using this method:
terr = 0
       For Each objprops In objpropsets
            If objprops.Name = "Custom" Then
                ' checks to see if Total Cost property already exist
                For Each objprop In objprops
                    If objprop.Name = "Total Cost" Then
                        terr = 0
                        Exit For
                    Else
                        terr = 1
                    End If
                Next objprop
                If terr = 1 Then
                    'DO THIS...
                    MessageBox.Show("No Total Found so ...DO THIS...")
                End If
            End If
        Next objprops
I wanted to use something more direct.  I've tried the following to no avil:
If Not (objpropsets.Item("Custom").Item("Total Cost") Is Nothing) Then
            MessageBox.Show("IS NOTHING Total Cost Does Exsist")
        Else
            MessageBox.Show("IS NOTHING Total Cost DOES NOT Exsist")
        End If
What is the bast way to test for a custom property???
Thank you much for the help!
~Matt
Posted by: Matt Johnson
Post date: 8/1/2008 9:38:32 AM
RE: How to test for Custom Prop?
Klaus Dahlenburg replied in the Solid Edge forums. Here is his response:
Matt,
the coding will raise the error 'Subscript out of Range', so be warned.
In VB6 I would code this way:
Dim oProps As Object
Dim oProp As Object
Set oProps = mDraft.Properties.Item("Custom")
On Error Resume Next
Set oProp = oProps.Item("Total Cost")
' alternate way
' Set oProp = mDraft.Properties.Item("Custom").Item("Total Cost")
If not (oProp is nothing) Then
MsgBox ("Total Cost Does Exsist")
Else
MsgBox ("Total Cost DOES NOT Exsist")
End If
err.clear
Set oProp = Nothing
Set oProps = Nothing
When there is no need for the object "Total Cost" the If Not (... is Nothing) might
be used as well
Klaus
Posted by: Jason Newell
Post date: 8/3/2008 7:29:35 PM
Thanks Jason!
Post date: 8/4/2008 4:05:18 AM
