How to use SEPartX control?
How to use SEPartX control in C# of VS2008 ?
Code:
axSEpartX1.PartFile = @"D:\1.par";
Error Message:
Exception of type 'System.OutOfMemoryException' was thrown.
Thanks.
Posted by: fat kids
Post date: 1/6/2010 7:29:23 PM
RE: How to use SEPartX control?
I'm having exactly the same problem. Right now i'm converting an old ''viewer'' made in vb6 to vb.net and this error occur. Works fine on Xp but on windows 7 it crashes.
Maybe i should use a different framework ? right now i'm using 4.0 client ?
Posted by: Alex Gagnon
Post date: 6/27/2011 3:32:10 AM
Having the same issue please help
Alex
Post date: 6/27/2011 4:01:07 AM
It crashes my IDE when I'm in the Windows Form designer. I think someone needs to report this to GTAC and get them to fix it or tell us what we're doing wrong.
Posted by: Jason Newell
Post date: 6/27/2011 7:19:05 PM
It seems it doesn't work only on window7 when build with vb.net
Someone must know how to make this works ?
Alex
Post date: 6/29/2011 4:12:10 AM
Hey,
I've finally found a way to make it works. Just download the last Solid Edge Viewer ST3 and use those library instead of them coming from the solid edge itself and it works fine.
ALex
Post date: 7/19/2011 4:07:36 AM
