How to use SavePlotAsImage method?
What should be the second parameter for SevePlotAsImage method of the Plot object?
The signature is like this
Public Sub SavePlotAsImage( _
   ByVal bstrImageFilePath As String, _
   ByVal pDocument As Object _
 The first parameter is file path, no problem with that. But what is the second parameter? What should I pass?
