How to use "Convert to text" in DFT?
Hi all:
       I want to convert the Partlist to text through program in dft, Please tell me how to achieve.
      The function is the "Convert to text" in dft. How to achieve  the functional through program.
      Thanks.
Posted by: fat kids
Post date: 8/5/2010 6:37:10 AM
RE: How to use "Convert to text" in DFT?
Hi Fatkids,
if you want to have the text: PartsList.CopyToClipboard and get the text from Clipboard.
or the Function"Convert to text": select the PartsList first and call the command with objApp.StartCommand(40040)
JR
Posted by: JR
Post date: 8/5/2010 10:37:13 PM
JR,
I wonder, how to learn the all values of StartCommand?
This is off top, Sorry.
Posted by: Anton Bykov
Post date: 8/8/2010 8:40:37 PM
I´m with the same problem. I would like to extract the part list to a txt file, trying to use the copytoclipboard, but it returns the error "HRESULT 0x80004002, E_NOINTERFACE". I´m using Windwos 7 with SolidEdge ST2. I don´t understand because the same code I used into a Windows XP and SE ST and worked ok. Have you any idea of this problem? What solution you suggest?
I´ll be very thanks for your help, because I don´t know what to do . . .
Posted by: Márcio Buss
Post date: 8/9/2010 4:10:56 PM
Thanks, JR.
On your tips , my problem solved
Thanks.
Posted by: fat kids
Post date: 8/12/2010 3:49:30 AM
