How to used feature pattern in an Assembly
Hi everyone,I am trying to create pattern feature in assembley environment.I also read some previous thread but still problem is occur.Can anyone guide me how to paased argument for pattern method in below attched code:
Thanks.
SolidEdgeFramework.Application appl = null;
      SolidEdgeFramework.Documents docs = null;
      SolidEdgeAssembly.AssemblyDocument aDoc = null;
      SolidEdgeAssembly.Occurrences occurences = null;
      object featref = null;
      object faceref = null;
      string shellBodyName = @"D:\DCH\ShellBody.par";
      string LiftingLugSubAssemblyyName = @"D:\DCH\Lifting Lug SubAssembly.asm";
      try
                SolidEdgeCommunity.OleMessageFilter.Register();
                appl = SolidEdgeCommunity.SolidEdgeUtils.Connect(true, true);
                docs = appl.Documents;
                aDoc = (SolidEdgeAssembly.AssemblyDocument)docs.Add("SolidEdge.AssemblyDocument", Missing.Value);
                occurences = aDoc.Occurrences;
                Occurrence ShellBodyOcc = occurences.AddByFilename(shellBodyName);
                Occurrence LiftingLugSubAssemblyOcc = occurences.AddWithTransform(LiftingLugSubAssemblyyName, 0.812, 0, 3.5, 0, 0, 0);
                Occurrence[] patternPart = new Occurrence[1];
                patternPart[0] = LiftingLugSubAssemblyOcc;
                featref = aDoc.CreateReference(ShellBodyOcc,)
                AssemblyPattern asp = aDoc.AssemblyPatterns.Create(PatternName: "Lift Lug ",
                    MasterOccurrences: patternPart.ToArray(), FeaturePattern: ,
                    ReferenceFeature: );
Re: How to used feature pattern in an Assembly
Hi @VPJ19
What is the problem you are facing with this code?
Any error?
The sample code for 'CreateDuplicate' in the API help shows how to pass similar arguments as the Create method.
Also, some hints are in a similar discussion:
https://community.plm.automation.siemens.com/t5/Solid-Edge-Developer-Forum/How-to-create-Assembly-Pa...
Hi @Tushar,
For above case firstly I had used Create method, but this method is applicable only when reference object is featured type.But here reference point for pattern creation is a circle. So for this CreateAlongCurve method is useful, but I am confused for passing their arguments.How to select cylindrical edge as a curve for pattern creation?
Thanks.
~VPJ
