HowTo Delete Occurence FaceStyle
Changing the FaceStyle with
        Dim seOCC As SolidEdgeAssembly.Occurrence
        Dim seFaceStyle As SolidEdgeFramework.FaceStyle
        seFaceStyle = seASM.FaceStyles("Blue")
        For Each seOCC In seASM.Occurrences
            seOCC.FaceStyle = seFaceStyle
        Next
works. But HowTo delete (set to "(None)") the FaceStyle?
Jürgen
Posted by: Jürgen Niesner
Post date: 3/7/2011 1:09:55 AM
3 REPLIES 3
RE: HowTo Delete Occurence FaceStyle
Well, this is a quick, blind shot...
Have you tried this?
seOccFaceStyle = Nothing
Julian
Posted by: Julian Guillo
Post date: 3/8/2011 10:20:42 AM
FaceStyle = nothing does not work, it ends with an COM-Exception
When I read the FaceStyle from an Occurence without an FaceStyle (DropDownlist in the GUI says (none) ) I get nothing.
It seems that reading nothing work but setting nothing is not allowed....
Jürgen
Post date: 3/25/2011 12:03:30 AM
You should use the Style property and set it to an empty string!!
Posted by: Martin Bernhard
Post date: 3/25/2011 4:48:58 AM
