Hyperlink Access
Hi, I have created a draft file and inserted a text box. I have attached a hyperlink to the text box.I have written addin code to access the draft sheet and can locate the text box but cannot locate the hyperlink attached.Can anyone tell me if the hyperlink is accessible and if so, where I could find it in the structure of the sheet?
Thank you
Posted by: Peter Simpson
Post date: 9/26/2011 6:14:54 PM
