ILoader examples
Any help regarding how to use the TIFFLOADER would be nice.
I am looking to load tif files on a plan via automation.
Thanks Teus
Posted by: Teus Streef
Post date: 7/20/2006 3:52:13 AM
RE: ILoader examples
Hi Teus,
I'm not familiar with ILoader or TIFFLOADER. Can you post some links to documentation?
Posted by: Jason Newell
Post date: 7/20/2006 3:58:15 AM
The file is in the reference menu.(adding a reference file to the reference list. Same as adding Solid Edge object to the reference list)
It is called Tiff_Loader 1.0 Type Library. There is 2 other called Bmp_Loader and Jpeg_Loader as well.
I hope this helps
Teus
Post date: 7/20/2006 5:32:40 AM
Looking at the Type Library information, I don't really see any use for this API. i.e. I don't see any useful methods or properties that would allow you to do much with the file.
What exactly is it that you're trying to accomplish?
BTW, this API that you found is probably for internal Solid Edge use only. That's why we don't have any documentation for it.
Post date: 7/20/2006 6:03:36 AM
Jason,
Thanks for a quick reply.
I am looking to get the width and height of the tiff file. There is no easy way that I see of getting this info from a tiff.
Teus
Post date: 7/20/2006 6:08:24 AM
If found this and it works for what I need. Again thanks for your help Jason
Private Sub CommandButton2_Click()
Dim miDoc As MODI.Document
Dim miImage As MODI.Image
Set miDoc = New MODI.Document
miDoc.Create "C:\_a.tif"
Set miImage = miDoc.Images(0)
MsgBox "Height= " & miImage.PixelHeight & Chr(10) & "Width= " & miImage.PixelWidth
Set miImage = Nothing
Set miDoc = Nothing
End Sub
Post date: 7/20/2006 7:22:50 AM
