Icons for button
Hello All,
I have created 4 buttons on Solid Edge ST3 addin. I want to add different icons to each button. How can I do this? Please help me by providing suggestions or sample code.
Thank You
Posted by: Shruthi M
Post date: 8/29/2012 10:40:27 PM
Re: Icons for button
Did you call SetAddinInfoEx? The API takes in a resource module filename and image IDs for your buttons. The image is a glyph, which is a single bitmap that contains one image for each button (I use the tiling UI in the visual studio resource editor).
Take a look at the VC addin sample in the sdk (sdk\samples\addins\vc).
Posted by: R.D. Holland
Post date: 9/18/2012 3:35:53 PM
