Import DXF onto Draft - C#
Hello all,
I am just new to the forum, and new to Solid Edge. I hope one of you can help me with this question:
Among all tasks to automate, there is this step where the user Drag and Drops a DXF file into a Draft (dft).
After a day of searching, I am stuck. How to do this ?
I came to this, but it doesn't work for DXf files:
drawingView = drawingViews.Add<which one ?>
We use
- ST8;
- Visual Studio 2015 with C# .NET
Thank you all in advance !
Johan
Re: Import DXF onto Draft - C#
Update:
I solved it using these steps:
- Open the DXF with an Empty Draft;
- Selectall;
- Copy to Clipboard;
- Close the DXF drawing;
- Paste to 2DModel in file.
Cheers !
Good job @Johan. I was curious to see how this might work.
Terry Tyson
Software Automation Designer
I am trying to achieve the same thing- generate *.dft files from *.dxf files using VB.NET.
I can open *.psm, *.dft files with .Open, but when I try to do the same thing with *.dxf, I get this error:
"System.Runtime.InteropServices.COMException: 'Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))'
How did you open the *.dxf with an empty draft?
Silver Reinart
Hi Silver,
I made a method:
ClipCopyDxf ( application, FileName_DXF, FileName_DFT );
Tha looks like this: (you would need the 3rd line only)
        static private void ClipCopyDxf( SolidEdgeFramework.Application application , string Filename , string DraftEmpty )
            Console.WriteLine ( "In:  ClipCopyDxf" );
            WaitingForIdle ();
            application.Documents.OpenWithTemplate ( Filename, DraftEmpty );
            WaitingForIdle ();
            // Zoom Fit
            ZoomFitAll ( application );
            WaitingForIdle ();
            // Select All
            application.StartCommand ( SolidEdgeConstants.DetailCommandConstants.DetailEditSelectAllInView );
            WaitingForIdle ();
            // Copy to Clipboard
            application.StartCommand ( SolidEdgeConstants.DetailCommandConstants.DetailEditCopy );
            WaitingForIdle ();
            SolidEdgeFramework.SolidEdgeDocument D1 = application.GetActiveDocument();
            D1.Close ( false );
            Console.WriteLine ( "Uit: ClipCopyDxf" );
Hope this works for you.
jb
