In Solid Edge ST the SolidEdgePartSync::ExtrudedCutout interface does not contain the SideFaces prop
In the previous versions of SE there was the SideFaces property in the  SolidEdgePart::ExtrudedCutout interface. In the help of the  SolidEdgePartSync::ExtrudedCutout interface of SE ST is written that it contains the property but the relevante tlb and the interop files do not contain the property. What can the the reason?
I have SE ST MP9 installed.
Vadim
Posted by: Vadim Zlotnikov
Post date: 11/24/2009 1:15:10 AM
