Inactivate via API
Is there any way, through the API to "Inactivate" a part or sub-assembly? I'm using ST2.
Posted by: Terry Tyson
Post date: 7/8/2011 10:26:47 AM
RE: Inactivate via API
Occurrence.Activate = False
Posted by: Jason Newell
Post date: 7/8/2011 10:30:51 AM
Wow! That was FAST!
Thanks Jason.
Post date: 7/8/2011 10:34:38 AM
If I know the answer and have time, I typically try to respond quickly. Problem is I have had either lately. ;-)
Post date: 7/8/2011 3:51:33 PM
