Inactive and Active status of occurance
Hi all,
How to get the status of  "Active" or "Inactive" of an occurance or suboccurance.
Jaya
Posted by: jaya priyan
Post date: 1/27/2008 11:06:22 PM
Re: Inactive and Active status of occurance
Did you ever figure this out?
Use the Activate proprety
JB
VS2015, SE ST10
Ah, OK. Thanks. Overlooked this as it looked like a method for setting active/inactive. Assume I was being dumb then and this will report the active/inactive status of an occurrence too? Dim IsActive = Occurrence.Activate?
Yes, as Activate is a Property it has a get and set function.
The name is misleading ;-)
A = occ.Activate reads the current activation state while occ.Activate = True/False activates or deactivates the occurrence
JB
VS2015, SE ST10
