Independent application without SE
Hi all
I have a filefolder with some SE part files, I want to delete the dimensions in every file, So can i develop a independent application without SE running to batch these files? some clues from you will be appriciated!
Thank in advance !
Posted by: peckham peckham
Post date: 3/14/2011 4:31:09 PM
3 REPLIES 3
RE: Independent application without SE
You will need to automate full Solid Edge in this case. Their external APIs are fairly limited to things like file properties and links.
Posted by: Jason Newell
Post date: 3/14/2011 7:38:00 PM
Hi Jason
Thanks for your reply! i was away for some days, so cannot reply in time.
can you show me how to automate full Solid Edge?
is it difficult to do?
peckham
Post date: 3/22/2011 3:08:26 PM
Download the .zip attached to Developer Conference Material (2005 - 2007) and look at the examples.
Post date: 3/28/2011 1:25:00 AM
