Info about ISolidEdgeBar
HI,
I need to check if an Edgebarpage is already added to a document.
There is a way to enumerate/list the edgebarpages of a document?
I tried on the SDK, but I cant find a way to do this.
ISolidEdgeBar
- AddPage Method
- RemovePage Method
- SetActivePage Method
Thanks in advance for any info.
Best Regards
Massimo
Posted by: Massimo Magris
Post date: 3/5/2009 1:42:51 AM
RE: Info about ISolidEdgeBar
Massimo,
What we typically do is keep track of it ourself in the addin code. In ST, they added AddInEdgeBarEvents which you can get via ISEAddInEx.AddInEdgeBarEvents. They added this because I complained that it was too difficult to keep track of. So, that event set will raise AddPage, RemovePage & IsPageDisplayable events. I do not have an example yet because I haven't looked into it.
Posted by: Jason Newell
Post date: 3/9/2009 8:31:24 PM
