Info about ST User Interface
HI,
some infoo about SolidEdge user interface.
1. How to insert controls to a toolbar (example a drop down list or a inputbox)
2. How to create toolbars group programmatically
3. How to enable/disable toolbars commands buttons?
Thanks in advance for the infos.
Best Regards
Massimo
Posted by: Massimo Magris
Post date: 3/13/2009 12:24:54 AM
RE: Info about ST User Interface
HI,
found the info in SDK\toolbars.
Thanks, regards
Massimo
Post date: 3/16/2009 10:37:02 AM
