Insert Image
Olá a todos!
Estou tentando inserir uma imagem via programação.
Poderiam me ajudar nesta tarefa?
Consultei o Help do Solid Edge e encontrei:
Images2d
mk:@MSITStore:C:\Arquivos%20de%20programas\Solid%20Edge%20ST\SDK\sesdk.chm::/html/e3bb216f-6de2-693f-16a1-fce614e7f719.htm
Não consegui avançar na construção.
Dim objImage As SolidEdgeFrameworkSupport.Image2d
Dim objImages As SolidEdgeFrameworkSupport.Images2d
objImages.AddImage("", "")
Grato
Edson Jesus
Hello everyone!
I'm trying to insert an image programmatically.
Could help me in this task?
I consulted the Help of Solid Edge and found:
Images2d
I could not move forward in building.
Grateful
Edson Jesus
Posted by: Edson Silva de Jesus
Post date: 6/4/2010 5:28:21 AM
RE: Insert Image
Do you want insert a image in PartProfile?
Posted by: JR
Post date: 6/7/2010 1:39:06 AM
RE: Insert Image
Acredito não ter sido tão claro, me desculpe.
A idéia é inserir uma imagem em ambiente drawing (draft).
I believe it was not so clear, sorry.
The idea is to insert a picture into drawing environment (draft).
Grato
Edson
Post date: 6/7/2010 2:54:38 AM
RE: Insert Image
AddImage and Image2d is only for Part/SheetMetal
If you want insert a picture into draft, you can use Cipboard or SmartFrame2d.
For SmartFrame2d you must create a SmartFrame2d on the Sheet and insert the image with CreateEmbed(FileName) or CreateLink(FileName).
JR
Posted by: JR
Post date: 6/7/2010 9:02:25 PM
RE: Insert Image
Good morning!
After we had much struggle, I found a solution to the problem with inserting images.
Follows the work:
Dim oSymbol As SolidEdgeFramework.Symbol2d
objDraft = objApplication.ActiveDocument
For Each Sht In objDraft.ActiveSection.Sheets
objBackground = objDraft.Sections.BackgroundSection.Sheets.Item("A4-Sheet")
'||||||||||||||||(Symbols)|||||||||||||||||||||
oSymbol = objBackground.Symbols.Add(SolidEdgeConstants.OLEInsertionTypeConstant.igOLEEmbedded, "C:\Leg_A4.dft", 0, 0)
Edson Jesus
Post date: 6/8/2010 1:42:55 AM
