Insert part file in assembly
How to do it?
I would like to insert a part file into an assembly currently I use this:
doc.Occurrences.AddByFilename (partname)
this works, but the part is grounded after insert, I would like to see that the part is not grounded and that the user is asked to create relations.
Is there anyone that can help me?
Posted by: flavio flavio
Post date: 12/27/2006 8:10:40 AM
RE: Insert part file in assembly
Hello 097
Code fragment (+ See \Solid Edge V19\Custom\SELibrary)
global vars (+ objSEApp)
Private WithEvents objFileUIEvents As SolidEdgeFramework.ISEFileUIEvents_Event
Private sPlaceFileName As String
Private Sub InsertPart(ByVal sFile As String)
If File.Exists(sFile) Then
sPlaceFileName = sFile
objFileUIEvents = CType(objSEApp.FileUIEvents, SolidEdgeFramework.ISEFileUIEvents_Event)
If Not (objFileUIEvents Is Nothing) Then
objSEApp.StartCommand(SolidEdgeFramework.SolidEdgeCommandConstants.seAssemblyPlacePartCommand)
objFileUIEvents = Nothing 'with events variable
End If
End If
End Sub
Private Sub objFileUIEvents_OnPlacePartUI(ByRef FileName As String, ByRef AppendToTitle As String) Handles objFileUIEvents.OnPlacePartUI
On Error Resume Next
FileName = sPlaceFileName
End Sub
Pavel Janiga
Posted by: Pavel Janiga
Post date: 12/28/2006 5:25:04 AM
thx, worked great!
Post date: 2/1/2007 3:47:51 AM
