Insight: How to create unmanaged copy from a list of solidedgedocuments?
HI,
how to create unmanaged copy from Insight, from a text list of SolidEDge files, via API?
Example: List.txt
http://site/part1.par
http://site/part2.par
http://site/asm.asm
Thanks in advance,
Best Regards
Massimo
Posted by: Massimo Magris
Post date: 9/28/2009 1:07:20 PM
RE: Insight: How to create unmanaged copy from a list of solidedgedocuments?
use the InsightClass.ExportDocumentsFromServer(...) method from the RevisionManager API.
Posted by: Wolfgang Kunert
Post date: 9/28/2009 9:16:37 PM
Hi Wolfgang,
thanks for the replay, this is exactly what I need.
Do you have an example of how to get to the Insight Class?
How the list of files must be passed? Array?
Thanks in advance,
Best Regards
Massimo
Post date: 10/2/2009 1:10:58 AM
Hi Massimo,
you didn't specify which Solid Edge version and which programming environment (VB6 or .NET VB/C#) you intend to use, but you find the information needed in the standard Solid Edge help "Programming Solid Edge". Search for the method name(s) i gave you and you will find the information needed together with some example code.
Post date: 10/10/2009 10:08:02 PM
