Insigth: SQL QUERY to extract info
HI,
where are stored Name,Title and Revision in SQL for Insight?thanks in advance.
Massimo
Posted by: Massimo Magris
Post date: 10/6/2009 3:22:27 AM
RE: Insigth: SQL QUERY to extract info
Hi Massimo,
access to those values should be possible using the Insight API method "GetFilePropertiesFromServer". Explanation and sample code you find in the standard Solid Edge help "Programming Solid Edge".
Posted by: Wolfgang Kunert
Post date: 10/10/2009 10:10:55 PM
