InterPart variable link creation from API
Hi Guys,
if it's already discussed, maybe my search strategies were wrong, BUT
when we create links between part's variables through UI, its a quite straightforward process, and ends up with a formula, kind of
u"@'C:\\path\\to\\the\\referenced\\part.par'!'123a'"
Could somebody explain, where that part after exclamation mark comes from, or, in other words, how could I create references to variables of other parts from API?
Thanks, regards,
András Kovács
Re: InterPart variable link creation from API
as I suppose after hanging around in the docs, it's going to be an OLE link to a specific variable. Its still a question, how to get such a reference from API???
Fineally, there are
CopyToClipboard ()
EditFromClipboard()
methods for an item of Variables collection  (and NOT  for a variable object!!!) which are designed to do this job --- through the OS clipboard.
