Hello everyone,
I am trying to get the list of all variables from variable list that are connected to an excel list, but i keep getting an exception "Unable to cast COM object of type 'System.__ComObject' to class type "SolidEdgeFramework.variable".
here is my code:
Dim seApp As SolidEdgeFramework.Application
Dim seDocs As SolidEdgeFramework.Documents
Dim ASMdoc As SolidEdgeAssembly.AssemblyDocument
Dim seVariables As SolidEdgeFramework.Variables = Nothing
Dim objVarList As SolidEdgeFramework.VariableList = Nothing
Dim seVariable As SolidEdgeFramework.variable = Nothing
seApp = CType(Marshal.GetActiveObject("SolidEdge.Application"), SolidEdgeFramework.Application)
Catch ex As Exception
If Err.Number <> 0 Then
seApp = CType(CreateObject("SolidEdge.Application"), SolidEdgeFramework.Application)
End If
seDocs = seApp.Documents
End Try
ASMdoc = CType(seDocs.Open(FileName), SolidEdgeAssembly.AssemblyDocument)
seVariables = CType(ASMdoc.Variables, SolidEdgeFramework.Variables)
objVarList = CType(seVariables.Query("*"), SolidEdgeFramework.VariableList)
For n = 1 To objVarList.Count
seVariable = CType(objVarList.item(n), SolidEdgeFramework.variable) 'here I am getting an exception
Formula = seVariable.Formula
VarName = seVariable.Name
If Formula <> "" AndAlso Formula.Substring(0, 1) = "@" Then
xlWb.Range("A" & k).Value = VarName
xlWb.Range("B" & k).Value = Formula
xlWb.Range("C" & k).Value = FileName
k = k + 1
End If
End Try
Does someone have an idea what is wrong with my code?.. Any help is highly appreciated...
Best regards, salwadora
Posted by: Salwadora
Post date: 2/4/2013 5:01:35 AM
the objects in the VariableList may have be of 3 different types (at least these 3 I have already seen):
* variable
* Dimension
* AsmRefPlane (only in Assembly environment)
It is quite probable, that your object is one of the second or third type!!
Posted by: Martin Bernhard
Post date: 2/4/2013 5:03:01 PM
Here is the answer. I wrote this quick so it doesn't necessarily represent best practices but you'll get the idea. Working with variables suck!
Also note my comments at the top of the code.
[code type=vbnet]
Imports System.Runtime.InteropServices
' .NET Framework 4
' Embed Interop Types = False
Module Module1
Sub Main()
Dim objApplication As SolidEdgeFramework.Application = Nothing
Dim objAssemblyDocument As SolidEdgeAssembly.AssemblyDocument = Nothing
Dim objVariables As SolidEdgeFramework.Variables = Nothing
Dim objVariablesList As SolidEdgeFramework.VariableList = Nothing
Dim i As Integer
objApplication = CType(Marshal.GetActiveObject("SolidEdge.Application"), SolidEdgeFramework.Application)
objAssemblyDocument = CType(objApplication.ActiveDocument, SolidEdgeAssembly.AssemblyDocument)
objVariables = CType(objAssemblyDocument.Variables, SolidEdgeFramework.Variables)
objVariablesList = objVariables.Query("*")
For i = 1 To objVariablesList.Count
Dim objVariableListItem As Object
Dim objectType As SolidEdgeConstants.ObjectType
objVariableListItem = objVariablesList.Item(i)
' .Type property is the key to the whole thing.
' Maps to SolidEdgeConstants.ObjectType.
objectType = objVariableListItem.Type
Dim objDimension As SolidEdgeFrameworkSupport.Dimension = Nothing
Dim objVariable As SolidEdgeFramework.variable = Nothing
Select Case objectType
Case SolidEdgeConstants.ObjectType.igDimension
objDimension = CType(objVariableListItem, SolidEdgeFrameworkSupport.Dimension)
Case SolidEdgeConstants.ObjectType.igVariable
objVariable = CType(objVariableListItem, SolidEdgeFramework.variable)
End Select
End Sub
End Module
Posted by: Jason Newell
Post date: 2/5/2013 2:24:09 AM
Thank you both so much, the solution worked perfectly for me Smiley Happy
You were absolutely right, I was getting an exception whenever I tried to make a variable object out of dimension. How could I miss that?
Guys, you are the best!
Post date: 2/5/2013 3:43:41 AM
