Is it possible to create a reference block within the assembly?
Good Morning!
Is it possible to create a block in the assembly environment for reference only, and which disappears when the command is finished? Similar to the image below:
Has anyone seen anything like this?
Kabir Costa
Industrial Designer
kabircosta@gmail.com
Re: Is it possible to create a reference block within the assembly?
simplified enclosure might meet your needs
if not  maybe just a create n place dummy part.
but i think the enclosure command might be what you are looking for .
Matt Johnson
Teamcenter 10.1.6
Thanks Matt. Are you talking about this command?
EnclosureEnclosure
Do you have something similar in the assembly environment?
Kabir Costa
Industrial Designer
yes,  there is enclosure in assy as well!
Matt Johnson
Teamcenter 10.1.6
Further to Matt's suggestion, there is a feature called Zones.
Also this being posted on the developer forum, I guess you want to create this programmatically. So there's an API for zones as well:
In the Solid Edge UI, Zones are in the EdgeBar under Select Tools:
~Tushar
