Is named Attribut in AttributSet
For handling AttributSets there is a function IsAttributSetPresent this one works. But handling Attributs a function IsAttributPresent is missing so I tried my own solution:
Private Function IsAttributPresent( _
ByRef seAttributSet As SolidEdgeFramework.AttributeSet, _
ByRef sAttributName As String) As Boolean
Dim lAttribut As Long
Dim seAttribut As SolidEdgeFramework.Attribute
For lAttribut = 1 To seAttributSet.Count
seAttribut = seAttributSet.Item(lAttribut)
If seAttribut.Name = sAttributName Then
Return True
Exit Function
End If
Next
Return False
End Function
My problem: it fails in "seAttribut = seAttributSet.Item(lAttribut)"
Juergen
Posted by: Jürgen Karl
Post date: 11/16/2005 6:37:20 PM
