Is there an alternative to GetObject
in one of my macros i use GetObject to get a reference to a document. I use the document to get the ViewStyle and FaceStyle information from this file. FullName of the file as String is the only information i have at this moment.
source = CType(GetObject(fi.FullName), SolidEdgeDocument)
styler = New CModellStyler(destination, source)
This is the only function i use from Microsoft.VisualBasic Namespace.
Is there an alternative way to get a reference to the document without opening the file (visible) and without using VisualBasic Namespace?
Greetings from Germany
Christian
Christian Kunkel
https://c-k-m.info
Re: Is there an alternative to GetObject
You sure can. GetObject() is not much more than a wrapper for Marshal.BindToMoniker().
Imports System
Imports System.Collections.Generic
Imports System.Linq
Imports System.Text
Namespace MonikerTest
	Friend Class Program
		Shared Sub Main(ByVal args() As String)
			Dim filename = "C:\Users\jason_001\Desktop\Part1.par"
			Dim document = TryCast(System.Runtime.InteropServices.Marshal.BindToMoniker(filename), SolidEdgeFramework.SolidEdgeDocument)
			Dim application = document.Application
		End Sub
	End Class
End Namespace
Jason Newell
Solutions Architect
www.jasonnewell.net
Thank you Jason, works fine.
Christian Kunkel
Christian Kunkel
https://c-k-m.info
