Is this an API Problem?
I am working in Drafting Environment an I'm finding that the PrimaryLinearToleranceRoundOffType property on a dimension style does not change after placement.
I am basically trying to determine if the dimension is a fraction or a decimal in my code and I noticed that some dimensions were identified incorrectly.
It seems that if the dimension was placed as a decimal and then later changed to a fraction by right click properties, the PrimaryLinearToleranceRoundOffType does not change.
I see this with the Spy tool and with my program as well.
Can any one confirm that this may be a bug?
LMGi
www.TLMGi.com
Re: Is this an API Problem?
Could you provide a code snippet so that I can see exactly how you're trying to change it?
Jason Newell
Applications Architect
www.jasonnewell.net
Thanks for taking the time Jason.
So when I went to get you a code fragment I found my bug. So you did help me.
I should have been using the RoundOffType property instead of PrimaryLinearToleranceRoundOffType.
Thanks!
LMGi
www.TLMGi.com
