IsKeyDown help
I have a Console App (VB.Net) that runs as it is supposed to with error handling and a few user inputs along the way.
The App is very basic - could be "Hello World" for testing purposes.
I'd like to have a hotkey to run this app with that would automatically jump to either a GOTO statement or Sub if the key is being pressed while the .exe is being launched.
Is this possible?  I am having difficulties doing so.
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
3 REPLIES 3
Re: IsKeyDown help
Hi @Johnson_BigMatt,
Maybe this info will sort your problem.
1. Right click on the application, what you want to assign a keyboard shortcut key.
2. click on create Shortcut, move that shortcut to anywhere.
3. Now right click on the shortcut, go to properties, select the shortcut zone and then press any key to assign.
This will work with Ctrl+Alt+key or Ctrl+Shift+key.
Thanks & Regards
V.Sudheer
Re: IsKeyDown help
Hi Matt,
Events in a console app?
I think you could add a Form and hide it while it 'hopefully' still listens to events.
Here are a few discussions I found online:
https://social.msdn.microsoft.com/Forums/vstudio/en-US/b8342571-c1b3-403e-b762-cf4ba16e336e/console-...
https://bytes.com/topic/visual-basic-net/answers/377359-events-console-programs
and here's one on code-project:
https://www.codeproject.com/Articles/2357/Console-Event-Handling
and a simpler technique from DotNet Pearls:
https://www.dotnetperls.com/event-vbnet
Re: IsKeyDown help
THx all,   I found my issue!!!
I did not have a stopping point (Console.ReadKey(True)) in my test...  so it was appearing as it did not work, where indeed it had.
here was my test this morning...  and when i went back to check my real code i noted i did not have the wait points (Console.ReadKey(True))
Module Module1
    Sub Main()
        ''Check for Key Press,  If So GoTo _AutoRun
        If My.Computer.Keyboard.CtrlKeyDown = True Then  'IsKeyDown(Key.Ctrl) Then
            AutoRun()
        End If
        'this would be the main body of code, prior to wanting to add the bypass
        Console.Title = "ISKeyDownTest - FALSE"
        Console.BackgroundColor = ConsoleColor.White
        Console.ForegroundColor = ConsoleColor.Black
        Console.Clear()
        Console.Beep(1500, 250)
        Console.WriteLine("Ctrl Key is NOT Down")
    End Sub
    Sub AutoRun()
        'this would be calls only with no error handling.
        Console.Title = "ISKeyDownTest - TRUE"
        Console.BackgroundColor = ConsoleColor.Red
        Console.ForegroundColor = ConsoleColor.White
        Console.Clear()
        Console.WriteLine("Ctrl KEY is DOWN!!!")
    End Sub
End Module
Matt Johnson
Teamcenter 10.1.7
