Its possible to "cast" SolidEdgeDocumentPtr to AssemblyDocumentPtr?
HI,
I tried
AssemblyDocumentPtr pAssembly ;
pAssembly = AssemblyDocumentPtr (pModel) ;
But i get alwas a null pointer.
Thanks in advance, best regards
Massimo
Posted by: Massimo Magris
Post date: 2/15/2009 4:22:57 AM
RE: Its possible to "cast" SolidEdgeDocumentPtr to AssemblyDocumentPtr?
HI,
yes, it's possible, I was casting a SyncAssemblyDocumentPtr.
but how to create a function that work either for AssemblyDocumentPtr and SyncAssemblyDocumentPtr.?
for example:
AssemblyDocumentPtr assembly1 ;
SyncAssemblyDocumentPtr assembly2 ;
CountSuppressedOccurrences (assembly1) ;
CountSuppressedOccurrences (assembly2) ;
int CountSuppressedOccurrences (????? pAssembly)
//This function should work for both type of Assemblies
Post date: 2/15/2009 5:56:11 AM
Hi Massimo,
you can do this with C++ templates. I haven't used these much and don't have a working example, but you should find something pretty easily in google. This should get you started but may not be 100% correct:template int CountSuppressedOccurrences(T pAssembly)
Cheers
Calum
Posted by: Calum McLellan
Post date: 2/15/2009 9:35:55 PM
