Lag whit batch process of occurence properties
I have write a vba macro to changed, in batch the occurence properties.
In ST8 everything work well, but with ST9 the process lag.
It take 1 second for one true/false action.
It take more time whit the macro, then the regular process.
I have only found one way to bypass this lag.
I start the macro end I try to close the assembly, when the pop-up asking do you want to save appear.
A this moment, my macro run normaly, but I don't understand why!
Code:
oApp As SolidEdgeFramework.Application
oAsm As SolidEdgeAssembly.AssemblyDocument
oOcc As SolidEdgeAssembly.Occurrence
oApp.DelayCompute = True
Set oAsm = oApp.ActiveDocument
oApp.ScreenUpdating = False
Set oOcc = oAsm.Occurrences.Item (A00001.par:1)
oOcc.DisplayInSubAssembly = False
oOcc.DisplayInDrawings = False
oOcc.IncludeInBom = False
oOcc.IncludeInPhysicalProperties = False
oOcc.Visible = False
oOcc.DisplayAsReference = False
oOcc.IncludeInInterference = False
oOcc.Locatable = True
oApp.DelayCompute = False
oApp.ScreenUpdating = True
Thanks!
